Thread: Test Results questions
    duraleigh Guest
    Default Re: Test Results questions
    Anyway, I have several questions:
    1. Are these readings okay in general?
    2. My CC reading seems to be falling on its own. It was 1.0 yesterday and 1.5 two days before that, without shocking. Is that normal?
    3. What happens if CC is too high? Is it safe to swim?
    4. When my FC was 0.5 and my CC was 1.0 with DPT, the OTO test result was totally clear. Doesn't OTO measure TC? Shouldn't it have been around 1.5 then?
    5. My calcium seems very high. I tested it with an HTH test kit before I had the PS kit and it was 0. Since then I added four pounds of Cal Hypo shock that the prior owners had lying around. Is that enough to increase my calcium to 150 or did I test wrong? Will it go down by itself?
    Thanks for your help.
    [/quote]
    1. Bring your TC up around 2-5 and keep it there
    2. Yes...to an extent
    3. No problem, it's an indicator to shock it out of there but it causes no harm. You may notice "chlorine smell" more readily.
    4. Yes, OTO is TC. It's somewhat innacurate, however. I wouldn't consider your results a significant issue.
    5. Vinyl pool...calcium doesn't matter. Plaster pool....most folks think of 250 as ideal but you're not in danger....use up the rest of the Cal hypo if you've got it. It will not reduce much on it's own.
    Thanks Duraleigh.
    The pool is vinyl, so I'll ignore the calcium readings and not test for it again.
