Results 1 to 10 of 15
Thread: Water test Results
    May 2012
    Kentucky
    Question Water test Results
    Okay, my new pool has been open for 8 days. Her are my latest test #'s. from this afternoon. FC 18.2, CC 0, PH 7.0 (took 7 drops to get to 7.6), TA 70, CH 130, CYA 42, Saturation index 0.87. I use the Taylor K 2006 test kit. The pool was cleaned and supposedly balanced by pool company on Saturday Morning.(of course, I wasn"t home as it was un- announced they would be coming Sat. morn). The chems they sell and use are BioGuard Maintain Silk Smart Stiks for Chlorine, BioGuard Maintain Smart Shock and BioGuard inhibit Smart Algicide. The stabilizer is 100 % cyanuric acid. BioGuard Smart Pak Chems listed below.
    BioGuard Smart Pak – 3 simple steps to Crystal Clear Water
    Step 1- BioGuard Maintain Silk Smart Sticks
    93.9% Trichloro-s-triazinetrione
    6.1% other ingredients
    Step 2-BioGuard Maintain Smart Shock
    63.05% Sodium dichloro-s-triazinetrione
    0.73% Copper Citrate (copper as metallic =0.26%)
    (available chlorine 39%)
    Step 3-BioGuard Inhibit Smart Algicide 1.25 ounces for 7500 gallon pool weekly
    Copper (metallic) 3.3% , derived from copper sulphate pentahydrate, (Cas No. 7758-99-8)
    Other ingredients 96.7% (contains polymeric polyacrylate and gluconate stabilizing agents)
    Ph needs to be 7.2-7.6
    CYA- minimum 30-40ppm
    Routine shock maintenance weekly
    I need to raise PH, Do you think that Borax will be okay to use with these products.
    I need to lower chlorine level, Do I just quit adding anything until the ppm drops to what ?
    Anything else I should do?
    We swam today and I took test samples after we got out. The water temp was 86 F. we have had no bad results even though I think chlorine is high. I do respect your advice. I would like to at least use the chems they left with me til gone if possible. Thank You!
    Frank
    17k gal 16' x 32' IG concrete bottom FG sides 1985 , Hayward Pro S244T sand filter , Hayward Super pump 1 HP 12 - 24 hrs , using 8.25% bleach, K-2006C kit. PF=7
    Default Re: Water test Results
    Borax is okay to use with these products. However, both the trichlor and the dichlor are very acidic and are driving your pH down. Besides, the dichlor and algaecide both contain copper, and unless you want a metals problem to deal with. I would NOT allow that in my pool. ( BTW,copper is what turns dyed hair and fingernails green!)
    To bring your Cl levels down, just stop adding chlorine-- the sun will take care of it.
    May 2012
    Kentucky
    Thanks!
    If I read this correctly, I should not use the "smart shock" or "inhibit smart algicide? What would I use to shock the pool? What should I use as an algicide and do I need to add such a product to prevent algae?
    Frank
    Lehigh Valley, PA
    Few of us ever shock our pools unless we become aware of an incipient or active algae outbreak. We use plain 6% regular household bleach as sanitizing agent, adding an appropriate amount daily after testing for FC, CC, and pH. Water in balance that's properly maintained requires neither "shock" nor algicides.
    Now, your test results:
    FC = 18.2 – as Janet stated, that will drift down by itself. You want to maintain it between 3 ppm (never lower) and 6 ppm. When you test, you do NOT need to use a 25 ml sample. You can use 10 ml pool water, a heaping dipper of DPD powder, and multiply the drops you've counted by 0.5 to get the ppm.
    CYA = 42 – Is the number 42 an actual line on the comparator? Anything between 30 - 50 is okay though we see the best results with CYA nearer to 50 ppm.
    TA = 70 – that's okay but a little low. You might get better pH buffering with TA around 100. Get some Arm&Hammer baking soda, a large bag, in the baking aisle of your grocery store. Add 3 cups of baking soda. You can add it to the skimmer while the pump is running or in front of the return. Keep the water circulating so the baking soda mixes in, then test after 3 hours or so. You'll like be in the 80s somewhere. Add 3 more cups.
    pH = 7.0 – that's a bit low. It will go up somewhat with the addition of baking soda, so I wouldn't do anything with the pH just now. While you're out buying baking soda also pick up some 20 Mule Team borax in the laundry aisle. We may need that to fine tune the pH later.
    As to pH testing, when the FC (chlorine) is over 10 ppm the pH test is not valid. Let's let the FC drift down below 10 ppm and then deal with pH. You do NOT add more drops to get a better/different color. The chemicals are calibrated for five drops and what you see is what you have.
    While you're out shopping pick up some bleach. Plain, unscented, un-gel'd, just bleach. That will be your daily sanitizer and your "shock" and your algicide.
    Just a note --- generic bleach is fine and is what most of us use.
    May 2012
    Kentucky
    Thumbs up Re: Water test Results
    Quote Originally Posted by AnnaK View Post
    Few of us ever shock our pools unless we become aware of an incipient or active algae outbreak. We use plain 6% regular household bleach as sanitizing agent, adding an appropriate amount daily after testing for FC, CC, and pH. Water in balance that's properly maintained requires neither "shock" nor algicides. Thank You! I am kind of overwhelmed with reading so much info and was confused on the "Shock"
    CYA = 42 – Is the number 42 an actual line on the comparator? No, the comparator only shows 40 and 50 but was close to 40.
    TA = 70 – that's okay but a little low. You might get better pH buffering with TA around 100. Get some Arm&Hammer baking soda, a large bag, in the baking aisle of your grocery store. Add 3 cups of baking soda. You can add it to the skimmer while the pump is running or in front of the return. Keep the water circulating so the baking soda mixes in, then test after 3 hours or so. You'll like be in the 80s somewhere. Add 3 more cups. I picked up 2- 2 lb. boxes and added half a box. I will check in the morning and add more.
    As to pH testing, when the FC (chlorine) is over 10 ppm the pH test is not valid. Let's let the FC drift down below 10 ppm and then deal with pH. You do NOT add more drops to get a better/different color. The chemicals are calibrated for five drops and what you see is what you have. The drops I added were part of the "base demand " test that my taylor kit said to use. It took six drops of R-0006 to reach a ph level of 7.6. The PH was around 7 to 7.1 before the pool store "balanced" the pool but, I will wait until FC drops below 10 ppm to check PH again.
    Thanks again, I wanted to try to use pool store chemicals as I have a small pool and wanted to support him a little bit. They were supposed to balance the pool but, obviously, they did not. I will go to "BBB" method but may use the BioGuard Maintain Smart silk sticks until gone if that is not a problem. (at least occasionally). I did pick up 3 gallons of bleach and some Borax.
    Thank you very much for your time and advice.
    Lehigh Valley, PA
    What you've done so far sounds good. The ~16 oz of baking soda you've put in will raise your TA around 10 ppm. You would be okay to add the rest of that box.
    Thank you for clarifying the "drops" situation. I have never done a base or an acid demand test and am just not familiar with the procedure.
    I would like to say to you, okay, go ahead and use those silk sticks but that 6.1% "other ingredients" concerns me. I don't like putting stuff in my pool when all I know is that it's "other". I'm hoping PoolDoc will know what that might be. Until we find out I'd say, set it aside. I know with certainty that I wouldn't use the Step 2 and Step 3 chemicals. Both contain copper and who knows what else. It's what Watermom so fondly calls 'voodoo ingredients'
    May 2012
    Kentucky
    Okay, My FC is now down to 5.5. CC 0.5 , TA is at 80, PH 7.1 (took 3 drops R-0006 to get to 7.6) Whats next on my to do list? I did pick up some Borax
    Lehigh Valley, PA
    Add 3 more cups of baking soda to raise the TA a little more. Let that mix in and circulate for an hour, then add 2 cups of borax. My best guess is that your TA will then be in the 90s somewhere and the pH around 7.4/7.5
    The CC of .5 is okay but we'd rather have it at zero.
    From here on you test daily for FC, CC, and pH. You add enough bleach to keep the FC between 3 and 6 ppm. This is based on your reported CYA of 40-something. In your pool, 1/2 gallon of 6% bleach will add approximately 5 ppm of FC. You should be okay with adding 1 quart of 6% bleach every evening, depending on the swimmer load that day. Test the water in the evening. It's going to be a little bit of trial and error and we want to err on the high side. You will soon get to know your pool and develop a 'feel' for what it needs.
