Results 1 to 10 of 15
Thread: Water test Results
    Lehigh Valley, PA
    Default Re: Water test Results
    Few of us ever shock our pools unless we become aware of an incipient or active algae outbreak. We use plain 6% regular household bleach as sanitizing agent, adding an appropriate amount daily after testing for FC, CC, and pH. Water in balance that's properly maintained requires neither "shock" nor algicides.
    Now, your test results:
    FC = 18.2 – as Janet stated, that will drift down by itself. You want to maintain it between 3 ppm (never lower) and 6 ppm. When you test, you do NOT need to use a 25 ml sample. You can use 10 ml pool water, a heaping dipper of DPD powder, and multiply the drops you've counted by 0.5 to get the ppm.
    CYA = 42 – Is the number 42 an actual line on the comparator? Anything between 30 - 50 is okay though we see the best results with CYA nearer to 50 ppm.
    TA = 70 – that's okay but a little low. You might get better pH buffering with TA around 100. Get some Arm&Hammer baking soda, a large bag, in the baking aisle of your grocery store. Add 3 cups of baking soda. You can add it to the skimmer while the pump is running or in front of the return. Keep the water circulating so the baking soda mixes in, then test after 3 hours or so. You'll like be in the 80s somewhere. Add 3 more cups.
    pH = 7.0 – that's a bit low. It will go up somewhat with the addition of baking soda, so I wouldn't do anything with the pH just now. While you're out buying baking soda also pick up some 20 Mule Team borax in the laundry aisle. We may need that to fine tune the pH later.
    As to pH testing, when the FC (chlorine) is over 10 ppm the pH test is not valid. Let's let the FC drift down below 10 ppm and then deal with pH. You do NOT add more drops to get a better/different color. The chemicals are calibrated for five drops and what you see is what you have.
    While you're out shopping pick up some bleach. Plain, unscented, un-gel'd, just bleach. That will be your daily sanitizer and your "shock" and your algicide.
    Just a note --- generic bleach is fine and is what most of us use.
    May 2012
    Kentucky
    Thumbs up Re: Water test Results
    Quote Originally Posted by AnnaK View Post
    Few of us ever shock our pools unless we become aware of an incipient or active algae outbreak. We use plain 6% regular household bleach as sanitizing agent, adding an appropriate amount daily after testing for FC, CC, and pH. Water in balance that's properly maintained requires neither "shock" nor algicides. Thank You! I am kind of overwhelmed with reading so much info and was confused on the "Shock"
    CYA = 42 – Is the number 42 an actual line on the comparator? No, the comparator only shows 40 and 50 but was close to 40.
    TA = 70 – that's okay but a little low. You might get better pH buffering with TA around 100. Get some Arm&Hammer baking soda, a large bag, in the baking aisle of your grocery store. Add 3 cups of baking soda. You can add it to the skimmer while the pump is running or in front of the return. Keep the water circulating so the baking soda mixes in, then test after 3 hours or so. You'll like be in the 80s somewhere. Add 3 more cups. I picked up 2- 2 lb. boxes and added half a box. I will check in the morning and add more.
    As to pH testing, when the FC (chlorine) is over 10 ppm the pH test is not valid. Let's let the FC drift down below 10 ppm and then deal with pH. You do NOT add more drops to get a better/different color. The chemicals are calibrated for five drops and what you see is what you have. The drops I added were part of the "base demand " test that my taylor kit said to use. It took six drops of R-0006 to reach a ph level of 7.6. The PH was around 7 to 7.1 before the pool store "balanced" the pool but, I will wait until FC drops below 10 ppm to check PH again.
    Thanks again, I wanted to try to use pool store chemicals as I have a small pool and wanted to support him a little bit. They were supposed to balance the pool but, obviously, they did not. I will go to "BBB" method but may use the BioGuard Maintain Smart silk sticks until gone if that is not a problem. (at least occasionally). I did pick up 3 gallons of bleach and some Borax.
    Thank you very much for your time and advice.
    17k gal 16' x 32' IG concrete bottom FG sides 1985 , Hayward Pro S244T sand filter , Hayward Super pump 1 HP 12 - 24 hrs , using 8.25% bleach, K-2006C kit. PF=7
    Lehigh Valley, PA
    What you've done so far sounds good. The ~16 oz of baking soda you've put in will raise your TA around 10 ppm. You would be okay to add the rest of that box.
    Thank you for clarifying the "drops" situation. I have never done a base or an acid demand test and am just not familiar with the procedure.
    I would like to say to you, okay, go ahead and use those silk sticks but that 6.1% "other ingredients" concerns me. I don't like putting stuff in my pool when all I know is that it's "other". I'm hoping PoolDoc will know what that might be. Until we find out I'd say, set it aside. I know with certainty that I wouldn't use the Step 2 and Step 3 chemicals. Both contain copper and who knows what else. It's what Watermom so fondly calls 'voodoo ingredients'
    May 2012
    Kentucky
    I would like to say to you, okay, go ahead and use those silk sticks but that 6.1% "other ingredients" concerns me. I don't like putting stuff in my pool when all I know is that it's "other". I'm hoping PoolDoc will know what that might be. Until we find out I'd say, set it aside. I was just wondering if Pooldoc saw this and knows what that 6.1% other ingredients might be? I know with certainty that I wouldn't use the Step 2 and Step 3 chemicals. Both contain copper and who knows what else. It's what Watermom so fondly calls 'voodoo ingredients'
    May 2012
    Kentucky
    Okay, My FC is now down to 5.5. CC 0.5 , TA is at 80, PH 7.1 (took 3 drops R-0006 to get to 7.6) Whats next on my to do list? I did pick up some Borax
    Lehigh Valley, PA
    Add 3 more cups of baking soda to raise the TA a little more. Let that mix in and circulate for an hour, then add 2 cups of borax. My best guess is that your TA will then be in the 90s somewhere and the pH around 7.4/7.5
    The CC of .5 is okay but we'd rather have it at zero.
    From here on you test daily for FC, CC, and pH. You add enough bleach to keep the FC between 3 and 6 ppm. This is based on your reported CYA of 40-something. In your pool, 1/2 gallon of 6% bleach will add approximately 5 ppm of FC. You should be okay with adding 1 quart of 6% bleach every evening, depending on the swimmer load that day. Test the water in the evening. It's going to be a little bit of trial and error and we want to err on the high side. You will soon get to know your pool and develop a 'feel' for what it needs.
    May 2012
    Kentucky
    Okay, my evening test result after adding baking soda and borax are FC 4.0, CC 0, TA 90, PH 7.3 Cya 60. I am going to add a quart of 6% bleach. Do I need to add more Borax and/or baking soda? Thanks
    Frank
    Go ahead and add your bleach--your pH and alk look fine to me.
    Lehigh Valley, PA
    It's looking great, Frank!
    Try to keep the FC between 3 and 6 ppm, test FC, CC, pH daily, add bleach as needed. Are you keeping a pool log? I use a notebook in which I write test results, type and amount of chemicals added, when I backwash/rinse, that sort of thing.
    The log can sometimes be your first clue of trouble, before you see or feel problems with the water, and can teach you to be proactive. At closing and opening you can refer back to previous years to see what you did and, if a problem comes up during the season, you can look back to see how you dealt with something similar in the past. It's also a good place to track money spent on pool related items.
    Enjoy your pool, you've worked hard to get it where it is.
