Your CYA level is perfect where it is so don't use any more trichlor tabs. Just use bleach for your source of chlorine. Bleach doesn't do anything to the stabilizer. Test your pool every evening and then add enough bleach to get the chlorine level back up to 6. If by the next evening, you have less than 3ppm of chlorine, you should take it a little bit higher. The goal is to have enough in there so that you never drop below the minimum required by your CYA level. (See the Best Guess Chlorine Chart.) Also test your pH every day for awhile.
After a few weeks of daily testing, you'll soon learn how your pool behaves and you may be able to test and add bleach every other day. But, you do NOT want your chlorine to drop below 3ppm or you risk an algae bloom.
