Results 1 to 10 of 22
Thread: New BBB user with FG pool
    Default Re: Introducing myself
    If you take a look at the Best Guess Chlorine Chart below, you can see that for a pool with a CYA of 40 needs to have chlorine levels between 3-6 all the time and if you are fighting algae or cloudy water, then your shock level would be 15.
    In a 13,000 gallon pool, each quart of 6% bleach will add just a little over 1ppm of chlorine. So, each evening, test your chlorine level and add enough bleach to raise it back up to 6ppm. The next evening, if you find that you have dropped below 3pm, then you'll know you need to maybe take the chlorine to 7. You want to be able to make it through an entire day without it dropping below 3ppm.
    Also, check your pH daily and keep it between 7.2-7.8.
    You might find the bleach calculator helpful. Look in the Forum Q & A section near the top of the forum homepage. One of the first few threads is called "bleach calculator" which has the link you can download to your computer. It actually has more than just the bleach calculator. If you click in the upper left hand corner, it will drop down a list of other available calculators you can use.
    Jun 2012
    New York
    Watermom: I really appreciate the insights here.
    I have another point to inquire: When adding bleach to a pool like mine, will the chlorine be unstable or will it somehow combine with the stabilizer present and not be so volatile?
    I'm not sure I know what you are asking. Bleach is not volatile in a pool. It does not combine with the stabilizer; they each do their own job. Bleach will do a great job in your pool. It is not a stabilized form of chlorine, but having chlorine be stabilized simply means that is has CYA (stabilizer) in it. Since you already have the stabilizer in your pool, all you need is the chlorine --- thus the bleach. Does that answer what you were asking?
    Jun 2012
    New York
    Default
    Sorry about the confusion. I thought that the Cl is volatile and thus needs to be stabilized. Since bleach has chlorine in it, isn't it volatile too. Maybe volatile is not the right word; I guess I mean does't the bleach use go up if its not stabilized with some compound?
    Thank you Watermom.
    I read your answer again and now understand how this works. Sorry if I asked you the same question again.
    Not a problem.
    Jun 2012
    New York
    Thank you;
    This whole thing is a great experience for me. It does raise one question: Why not just use bleach from the beginning?
    Quote Originally Posted by gorji View Post
    You can! Many of us do. But, if you use only bleach from the beginning, you will have to add your CYA separately. People who use stabilized forms of chlorine (trichlor and dichlor) that have the CYA in them have to monitor their CYA levels periodically throughout the summer to make sure they don't get too high. The people who just use bleach from the get go and thus have to add the CYA separately, pretty much can forget about CYA testing for the summer after that first week.
    To answer a couple of things more specifically:
    1. Chlorine, cyanuric acid and around 12 species of chlorinated cyanurates remain in equilibria with each other. For most interactions, the reaction kinetics are VERY fast.
    2. Chlorine is not volatile in a chemical or physical sense; only figuratively. Rather chlorine undergoes rapid hydrolysis in water, forming HOCl <=> -OCl, with both species subject to rapid photolysis when exposed to solar UV. Chlorinated cyanurate species are NOT subject to this photolysis, but remain in equilibria with those species. HOCl is the primary actor in most sanitation and oxidation; -OCl is not as active. But even though the presence of CYA greatly lowers the HOCl present, the chlorinated cyanurates form a LARGE reservoir of instantly available HOCl, so that stabilized chlorine appears more active in practice than the absolute level of HOCl present would suggest.
    -- membership upgraded.
    Jun 2012
    New York
    Thanks to all of you I'm doing well with the chemistry.
    Do the fiberglass pool have different ph, Cl, alkalinity requirements than normal liner covered pools?
    No.
    (I got the easy one, Watermom! )
