Results 1 to 8 of 8
Thread: pucks?
    Question pucks?
    so, now that I am a pool forum convert, I have another question.
    Veterans: do you use chlorine pucks in the skimmers, or simply rely on bleach for all chlorination?
    thank you
    rjf
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Default Re: pucks?
    After using pucks (in a malfunctioning Hayward feeder) and granular shock for 1 full season and CYA >100, I now will only ever use bleach.
    CaryB
    Go 'Canes!
    West, Texas
    Default Re: pucks?
    No pucks here, bleach only
    Boyd
    27' Round AG, 17,204 gallons, sand filter
    Proud Father of an Army Soldier
    Default Re: pucks?
    Neither. We don't recommend generally that you put pucks in the skimmer. When the pump is off, the dissolved chlorine can damage components. Better to spend $10-$15 on a floater and use that.
    Usually, we recommend bleach--there's never ANY reason not to use bleach as your chlorinator.
    However, if your CYA/Stabilizer is low, and your pH is high (like in new concrete/plaster pools) , Tri-Chlor pucks are a great way to fight the high pH, add CYA, and keep a constant level of chlorine in your water. But when CYA hits 50ppm (or whatever your desired maximum is) you need to switch to bleach.
    Also if pH takes a nose-dive and dips below 7.3, or below 7.0, you should stop using the pucks.
    MaryLee is offline Registered+ Thread Analyst MaryLee 0
    Southern New Hampshire
    Default Re: pucks?
    I use pucks in my chlorinator if I'm going to be out of town for a few days. I also use them for a few weeks at the beginning of the season when my CYA needs a boost (from draining, etc.).
    95% of the time it's strictly bleach.
    18 X 40 IG Vinyl
    3 1/2' ft to 8' deep
    Pentair DE Filter
    400K BTU Pentair Minimax heater
    Illinois
    Default Re: pucks?
    I use pucks in my chlorinator - is this OK? If not, what is the harm? If it is OK, what number should I set the chlorinator to?
    What is CYA?
    Default Re: pucks?
    I keep using them in the chlorinator, but set on low for a maintenance "security" dose. Otherwise, I add bleach and calhypo. Just keep monitoring all chems, use 60% poly as a algae preventative, keep the CL up, and enjoy!
    Default Re: pucks?
    Pucks in a chlorinator are not necessarily a bad thing, IF you take care to not let your pH get too low, and not to let your CYA (stabilizer) get too high, which is the usual problem. As your CYA level increases, your chlorine becomes less effective against "stuff" in your water, so your minimum Cl level must also increase to compensate. See Ben's Best Guess Chart for a guideline that a lot of us use to calculate necessary Cl levels for a given CYA.
  1. Floater pucks VS Skimmer pucks
    By ThaSatelliteGuy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-16-2011, 07:11 AM
  2. HTH 3-in-1 pucks
    By JBfromNJ in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-01-2007, 08:43 AM
  3. Pucks
    By jrv331 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-22-2007, 04:43 PM
  4. PH and pucks
    By aguaguy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-15-2006, 12:37 PM
  5. Do pucks get old?
    By Deuce2 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-27-2006, 10:03 AM
