Thread: HTH 6-Way Drop Test vs the Older HTH 5-Way Drop Test
    Default HTH 6-Way Drop Test vs the Older HTH 5-Way Drop Test
    I've been wondering what has changed from the old HTH 5-Way Drop Kit to the new 6-Way. Answer? Only the nice box the 5-Way came in...and the price, about $8 more.
    So here's my old 5-Way on the left and the 6-Way I bought today. (the OTO and pH on the original ran out and are replaced with generics). If you click on the image you should see it full size.
    Lehigh Valley, PA
    Default Re: HTH 6-Way Drop Test vs the Older HTH 5-Way Drop Test
    So what is the additional test in the 6-way?
    The OTO Bromine test, which is, of course, the same as the OTO TC test, with a different scale, is the "sixth test". In other words, there is no difference in the test kits, just the label. Oh, and the nifty box that they no longer provide.
    Lehigh Valley, PA
    Clever marketing.
  1. Drop Based Borate Test Kit.
    By rcy100 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2011, 09:23 PM
  2. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  3. Drop test kit question
    By jd.pool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2006, 10:28 AM
  4. My first drop test kit results
    By Rangeball in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 10:31 AM
  5. Salt drop test
    By doriec in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-28-2006, 12:18 AM
