Re: Hey! Just got my new test kit...now what?
Alright I added about 2.5 Gallons of generic Bleach and tested 20 minutes later. FC is now just under 6ppm (so I added a little more bleach) and after re-reading the instructions, my CC is 0.4ppm, not 0. I hope that doesn't change anything!
I had a box of 20 Mule Team Borax that conveniently had about 1/4 missing, so I poured the remainder in. I'll retest PH in the morning - not sure how long borax takes to have an impact.
Also, I purchased some CYA granuals at Walmart. According to their dosage instructions I needed to add 4lbs to raise my CYA to about 20ppm. Per your recommendation, I filled an old sock and tossed it into the skimmer basket. I bought an extra 4lbs in case I needed to raise it higher.
Now I'll wait 3 or 4 days to retest CYA, and I'll check the FC, CC, and PH in the morning...
I really appreciate the help!
Anything else I should do now that I have all of that heading in the right direction?
