Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 45
Thread: Convert indoor Baquacil pool to salt water chlorination?
    Jun 2012
    DC
    Default Re: To go to salt or not..lots of questions.
    PoolDoc,
    I have 4 sliding doors on one end of the room. The other side of the house are sliding doors and windows to the house. The pool store did not have an issue with pounding the pool with chlorine - I'm glad I asked. I can open the doors and rent a few large fans. I would also block the HVAC ductwork in the room.
    I started to empty the pool but could not figure out a way to flush the pipes. I also did not want to spend over 1K in water. I should have listened to the one person that instructed me to do the items in your list for concrete pools.
    I will wait to hear back on the off-gassing issue. Pool may be closed this summer.
    C. Chase
    I'm where I was, with off-gassing: I don't know.
    However, if you can ventilate the room continuously, it should be fine. Alternatively, Chem_Geek reminded me that you can use sodium percarbonate, instead of chlorine. It's not as messy, but it will cost 2x as much.
    Here are instructions (do NOT use the links! they go to Chinese sites now!):
    http://piscines-apollo.com/docs/baqu...conversion.pdf
    And, sources for percarbonate:
    http://www.soapgoods.com/Sodium-Perc...te-p-1001.html
    http://www.chemistrystore.com/cart.c...3&child=100581
    I checked Amazon, but they do not currently sell any plain percarbonate . . . and you do NOT want a detergent!
    Jun 2012
    DC
    PoolDoc,
    thanks for the info. From your post, should I assume sodium percarbonate will not have the off-gassing effect? I reviewed the procedures in the link - will there be anything to vacuum to waste? With the chlorine steps the instructions included vacuuming the bottom of the pool to waste. Will the sodium percarbonate clean the filter and the pipes?
    Any side effects I should be aware of?
    Thanks again.
    Regards,
    C. Chase
    Chem_Geek thinks not; I don't know for myself, but I trust his judgement and knowledge on that.
    It's not so much that there won't be any outgassing, but that whatever is outgassed won't be chlorinated by-products so are less likely to be harmful. Sodium percarbonate has hydrogen peroxide and generally it produces water when oxidizing other chemicals.
  6. #16
    Jun 2012
    DC
    Thanks Chem geek. Not only am I concerned with the toxicity to humans, I'm wondering what if anything it will do to the structure. Room is primarily covered in Drywall.
  7. #17
    Chlorine is DEFINITELY more of a problem for indoor structures than Baquacil. And, if you don't have continuous fresh air ventilation, the damage, especially to wiring, can be severe.
    I have extensive experience with indoor commercial pools . . . and have chosen to stay away from that topic here, because most owners find the information we provide complex enough . . . but managing indoor chlorinated pools is MUCH more complicated, with much less certain results.
    Honestly, the more you describe your situation, the more inclined I am to recommend that you STAY on Baquacil, as long as no one but your family uses it. (Baquacil is NOT an adequate sanitizer in a commercial environment). Baquacil can be used successfully long term, if you do two things:
    1. Replace 1/3 to 1/2 of your pool water every 6 months of use.
    2. Replace 100% of your filter media (sand or cartridge) every 12 months of use.
    It does NOT sound like you have an enclosure that was properly designed for a pool room. You are likely to have problems regardless, especially if the pool room walls are exposed to winter temps. You should inspect for corrosion and wiring damage REGARDLESS. But, if you use chlorine, the lack of a properly designed enclosure may well become critical.
    Sorry . . .
  8. #18
    Jun 2012
    DC
    Thanks PoolDoc. I was under the assumption the SWCG woulld keep the chlorine @ a very low level - is this not so? Would 1 -3 ppm be too much for an indoor pool? The pool store recommended those levels.
    If I stay on Bacquacil, how do I get rid of the current condition? Drain and replace? If so, how do I go about clearing the pipes?
    Regards,
    C. Chase
  9. #19
    Low levels of chlorine don't necessarily affect the problem - you STILL have to add enough to react with the people goo. The only things that reduce that is to allow the pool to be used only by people with non-oily skin, who don't sweat and never pee in the pool or use skin lotion. (So, showering and peeing first, can make BIG difference.)
    By the way, never, ever let a former competitive swimmer in your pool . . . unless you SEE them pee before they swim. They are ALL in the habit of peeing in the pool, a practice enforced by coaches who demand uninterrupted 2 hour practices by fully hydrated swimmers! (I'm speaking, as the father of two competitive swimmers, and the uncle of a third who has newly achieved national rank.)
    To get rid of water mold, enough peroxide and algaecide will do it, but I can't tell you how much is enough. Here's what I'd recommend though:
    1. Drain 100% of your pool (if the ground is dry enough so there's no risk of 'floating' the pool!)
    2. Replace your sand.
    Working on the chemical guide -- will return to this.
    http://www.archchemicals.com/Fed/BAQ...t_up_49309.pdf
  10. #20
    Jun 2012
    DC
    Thank you.
  1. New Member, New Pool, Lots of questions
    By riverwhiskey in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-22-2012, 08:56 AM
  2. New Member/New Pool/Lots of "old questions
    By box0785 in forum Pool Chemistry for Intex-type Pools
    Last Post: 05-29-2012, 09:32 PM
  3. Lots of questions...
    By melanieholloway in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2011, 06:38 PM
  4. HELP! my pump just died (lots of questions here)
    By Ken and Laura in forum Pool Equipment & Operations
    Last Post: 06-30-2006, 02:32 PM
  5. Broke ground and sewer, lots of questions
    By beary in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 05:02 PM
