Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Pool Equipment & Operations
Pump Replacement Recommendation (In-Ground)
FAQ
register
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
06-28-2012
02:04 AM
#5
Tooner
View Profile
View Forum Posts
--General User--
Elk Grove, CA
Re: Pump Replacement Recommendation (In-Ground)
OK. Thanks. The 2-speed looks like a good deal.
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Do I have too much pump for the pool...
Be Creative: Floating Pool Thermometer
In-ground cleaning system, pump motor replacement question
By kluczenk in forum Pool Cleaning: Manual or Automatic
0
Last Post:
05-20-2013,
05:46 PM
Pump/Filter Recommendation
By erickismyname in forum Pool Equipment & Operations
3
Last Post:
04-17-2012,
08:16 PM
Pump recommendation
By cmcq in forum Pool Equipment & Operations
5
Last Post:
07-14-2011,
09:39 PM
Recommendation(s) on pump, etc.
By Cal_Newbie in forum Above-Ground Pool Construction & Repair
3
Last Post:
10-25-2006,
03:28 PM
Pump recommendation
By irishkenj in forum Pool Equipment & Operations
3
Last Post:
06-21-2006,
10:19 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
