Results 1 to 10 of 20
Thread: Question about orange/brown stain...
    PopcornGirl is offline ** No working email address ** Thread Analyst PopcornGirl 0
    Baton Rouge, LA
    Unhappy Question about orange/brown stain...
    Ok, we're still trying to figure this one out...
    I have an in-ground, gunite pool (almost 5 years old) & I live in Southeast Louisiana. For the first 3 years, we used an electric, copper ionization system. At the end of the 3rd season, we removed the copper bars and tested the water; it showed almost no copper in the pool. As it was nearing winter, we let the pool filter just run but did not add chlorine until the following spring.
    All last summer, we used chlorine with great success! It was SO much easier than the copper ionization system!
    This winter, we did not neglect our pool as we previously had, but we didn't keep it completely *up* either... When we opened it 3 weeks ago, there was some leaf debris and algae, but we could see the bottom of the pool and the chemistry was not WAY off...
    We vacuumed the pool thoroughly, soaked and rinsed the cartridge filters, and then added acid & (after 3 hours) shocked the pool. Two days later, I added black algetrine because I noticed the black algae trying to come back (a problem that was introduced during our copper ionization days). Our calcium hardness was a bit low, so we added that a couple of days later. All of our levels are now *perfect*, and the black algae is all but gone, but there is this stubborn, orangish-brown stain on the bottom of my pool and at the base of the walls (where the floor curves up into the wall). The walls are pristine; no algae or stains at all.
    I have scrubbed and scrubbed. The local pool store is baffled. Then I reminded them that we used to use copper so they tested for that and it came back positive! HOW is that possible??? It's been almost 2 years since we have actively added copper to the pool. I know some algaecides use copper; did the black algaetrine do this? Is this stain even related to the copper level in my pool or is it something else entirely?
    I could really use some input here; I'm still a bit of a novice at all this and I don't want to do anything wrong & really screw up my pool.
    One final note (sorry to be so long-winded): Yesterday (per my pool store's instruction), I added 1 quart of Metal-Out to my pool with the instruction to wait 2 days, rinse my cartridge filters, and then repeat the process. It has been nearly 24 hours since I added the Metal-Out and there has been no noticeable change in the stain so I'm wondering if this is even the right course...
    I truly appreciate any help or direction you can give me!
    Thanks in advance,
    Baton Rouge, LA
    Default Link to Pics of the problem...
    Here are some pics I took the other day of the stained areas...
    Any thoughts???
    MyPool
    Default
    I am not an expert on metals in pools but I do have bit of a chemistry background. Your stains look more like iron than copper based on the color. Copper strains are usually blue to black. I am sure your water tests positive for copper unless you have drained and acid washed your pool you probably have a coating of copper deposited in your pool from your ionizer. Could your fill water have a high iron content? I have read posts on here on using ascorbic acid (vitamin c) to remove the stains and I know that many of the commercial stain removing products the pool stores sell are just ascorbic acid. Try taking a vitamin C tablet and holding it on the stain and see if the stain goes away. If it does then you know what you need to treat the stain. A sequestering/chelating agent usually will not remove a metal deposit. It only ties up metal ions in the water so they do not percipitate out as a stain.
    Hope I've been of some help.
    duraleigh Guest
    Default
    Hi, Summer,
    I have never had a metal issue but I think "Waterbear"'s post has it just right. It certainly looks like iron to me and the cure I see on this forum time and time again is vitamin C. It's available in bulk and I've seen folks here post where to get it but I can't remember. Someone will post soon, I'm sure.
    Dave S.
    P.S. be cautious about shocking 'til you get the iron (if it's iron) out of the pool.
    Baton Rouge, LA
    Default
    Thanks so much for your replies, Waterbear & Dave! I really appreciate your help.
    I had not considered iron...
    But where is it coming from??? We are on municipal water and Baton Rouge's water is notoriously SOFT (aggravatingly so!).
    Also, I am not a scientist (my degree is in history ) but why wouldn't Metal Out remove iron from the water?
    Finally, I know NOTHING about using ascorbic acid... do I need to stop the chlorine (I use a feeder with the discs) and do I need to let the chlorine level drop before adding the asc. acid?
    I'm sorry to be such a novice; this is all still very new to me!
    Thanks again,
    Default
    Soft water just removes calcium hardness. It has nothing to do with any possible dissoved metals which can come from numerous sources such as pipes, the ground your water source comes from, pollution, etc. It is possible to have soft water with a high iron content. First step would be to check your water for all metals. I have a big distrust of pool store testing from my own experiences. One time I brought in two different samples, one from my spa and one from my pool, and did not tell them that they were a connected system and that I had my spillover running for 4 hours right before I took the samples. One sample tested as having very low CYA and the other sample was low on CH and had very high TDS. I suspect it was error on the part of the (what looked like) high school girl who was doing the testing. There is a compnay that is supposed to make a metal stain identifying kit (I think it's Jack's Magic but I don't know anything about it) and Taylor sells kits for testing for varous metals as do other testkit companies (LaMotte). There might even be test strips that will at least tell you if metals are present but I would not trust them to tell you at what concentration. Iron is your most likely culprit and you probably still have a lot of copper in your pool. It might not be in the water but it is deposited on the surface and can leach back into the water if your pH drops.
    Good luck on fighting the stains!
