Results 1 to 3 of 3
Thread: New Above Ground pool question
    Jun 2012
    Ohio
    Default New Above Ground pool question
    I can think of a thousand questions but let me start with the two that are preventing me from pulling the trigger
    We have a problem with moles in our yard and have been unable to keep them out. Is their anything that can be done during pool installation to help nullify this problem from affecting our pool?
    Also, our ideal spot is 20ft from a very large tree. While not an issue now, I'm worried about future root problems. Any thoughts would be appreciated.
    Thanks,
    turnerg
    Default Re: New Above Ground pool question
    Welcome to The Forum!
    As far as the roots go, 20' away probably takes the roots out of the picture. The only way they'd mess with your A/G pool is if they broke the ground surface. As long as no roots break the surface within ~10' of the proposed pool, you'll be fine for the life of the pool.
    Moles, on the other hand, can and will tunnel under an A/G pool causing 'sink lines' which will overstress the liner. I can't think of any practical way to shield the pool area from mole invasion, so I'd say you need to eliminate them.
    HTH
  1. Question about above ground pool vac and pool pump timer from newbie.
    By momtoallgirls4 in forum Pool Equipment & Operations
    Last Post: 07-11-2012, 02:06 PM
  2. Above ground pool light question
    By LedZepFan in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2012, 10:04 PM
  3. in ground vinyl liner question
    By dweer in forum In-Ground Pool Construction and Repair
    Last Post: 05-23-2012, 05:36 PM
  4. Above ground pool Filter Question
    By UNITY520 in forum Pool Equipment & Operations
    Last Post: 05-08-2012, 11:24 AM
  5. Above ground pool question....you don't even want to know why!
    By SandyDittmer in forum Above-Ground Pool Construction & Repair
    Last Post: 09-26-2010, 07:06 PM
