Re: Help-Cloudy Greenish Water
If your cya is truely 200, you may want to drain and fill a lot of water - draining 1/2 your pool will take you to a cya of 100, and what we usually recommend is to have your cya somewhere between 30 - 50. Here is a chart to see where you have to keep your chlorine levels accoriding to how much cya is in your water:
Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
=> 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
=> 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
=> 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
=> 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
=> 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
So you see if your don't keep a minimum of 8ppm chlorine in your pool you will have algae - which is what seems to be happening to your water now. You will have to take your chlorine up to 25ppm to reach a shock level and keep it there by checking it a couple of times a day, to get rid of the algae.
Your alkalinity is a little high, and by adding calcium you may get cloudy water too. Stay away from the pool store, they will have your putting all kinds of stuff in the water, then they will tell you something is too high and you need something else to bring it down! Right now put enough bleach to get to 25ppm, keep your filter running 24/7, brush the pool and backwash frequently.
Northeast PA
