Thread: First Run, Kit arrived today
    Condo Steve Guest
    Default First Run, Kit arrived today
    Hi everyone,
    Had a package by the door today. My DPD powder opened during shipment so I don't have FC or CC readings. How does these numbers look to you?
    15,000 gal. inground plaster. Sample taken after 1 hr. pump run.
    PH: 7.5
    TC: 1.0
    TA: 110
    CH: 180
    CYA: 30
    Pool is open year round in S. Florida.
    Dosed the pool with bleach (after test).
    Pump runs from 20:00 to 23:00 for bleach additions during night.
    duraleigh Guest
    Default Re: First Run, Kit arrived today
    Hi, Steve your numbers look pretty good. By "dosed" I assume you put in enough bleach to bring your residual up to about 2-5ppm and will keep it there.
    How does your water look?
    Does your pump run other than the three hours you posted? It should.
    You might consider using CalHypo as your chlorine source 'til you get your Calcium level up around 250....that's about where most folks run a plaster pool.
    If your water looks nice...enjoy your pool.
    Quote Originally Posted by Condo Steve
    Hi everyone,
    That's a first*.
    Email me at pooldoc AT pool9 DOT net, with your kit serial # and real name, and I'll send you a replacement.
    Ben
    *Or at least, the first time I've heard of that -- I realize not everyone lets me know when something goes wrong.
    Condo Steve Guest
    Good idea with the Ca Hypo. Kill two birds.
    I run the pump for five hours in the afternoon also. The night shift is just for me and chemical additions.
    Thanks,
    Condo Steve
  1. Taylor 2006c arrived
    By jeremyweber in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-07-2011, 12:25 PM
  2. New test Kit arrived today. Here are the numbers!
    By GA Mark in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-22-2006, 09:48 PM
  3. Today is why we have a pool.
    By bparks in forum General Interest
    Last Post: 07-19-2006, 02:08 PM
  4. Got My 234 Today!
    By Sherra in forum DPD-FAS based testing
    Last Post: 05-03-2006, 11:02 PM
