Thread: Fiberstars 6008 Pool Light Hot Mirror bracket assemby
    Jun 2012
    Texas
    Default Fiberstars 6008 Pool Light Hot Mirror bracket assemby
    Hi, I just purchased a house with an inground pool that has this type of light. The light was extremely dim. When I took the assembly apart the above mentioned part has three pcs of glass that the bulb shines through before it gets to the optics cables. The middle of the 3 has caked on white material and is broken into 4 pcs. The other 2 glass pcs are clean. Does anyone think it would be ok to run this with only 2? I put it back together to run it tonight to see if it is brighter (surely it has to be, as the buildup was very strong on the pc i took out) thanks
    Default Re: Fiberstars 6008 Pool Light Hot Mirror bracket assemby
    We don't have a lot of folks here with a strong knowledge of those systems. You may want to post at poolspaforum.com.
  1. Replacing Fiberstars 6008
    By jewel in forum Pool Equipment & Operations
    Last Post: 06-14-2012, 02:35 PM
  2. pool step bracket
    By mike_311 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2012, 01:24 PM
  3. fiberstars lights dont light up!!!!!
    By aldoglez511 in forum Pool Equipment & Operations
    Last Post: 07-21-2011, 11:30 AM
  4. Fiberstars 6008 lamp (light bulb) replacement
    By rjmo22 in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2011, 11:48 PM
  5. Anybody have fiberstars jaxx/fx spa light
    By johnm92627 in forum In-Ground Pool Construction and Repair
    Last Post: 02-12-2007, 11:41 AM
