Results 1 to 8 of 8
Thread: rust stains from nails
    Condo Steve Guest
    Default rust stains from nails
    Hi,
    After Hurricane Wilma, our pool had several metal nails blown into it. They were not removed promptly (we were picking up branches and shingles and such) and now there are rust stains the size and shape of 10d nails on the plaster bottom. Is there a localized way of removing rust stains under water without acidifying the whole pool?
    Thanks,
    Condo Steve
    mbar's Avatar
    Ashland, PA
    Default Re: rust stains from nails
    Try taking a couple of vitamin C tablets, crushing them, putting them in a sock and rubbing it on the stain. You can also use ph down in a sock and doing the same thing. Let us know how this works.
    Northeast PA
    Condo Steve Guest
    Something to do this weekend. Swim down and rub the Vitamin-C pouch on the stain underwater?
    I'll try it.
    Thanks a bunch,
    Condo Steve
    mbar's Avatar
    Ashland, PA
    Yeah, but if the water is too cold, you can attach it to the skimmer pole and use that, or get a wet suit? Ha, ha, I finally opened my pool today and wow is it cold!
    Northeast PA
    Condo Steve Guest
    I'm in S. FLorida. Raiding the wife's medicine cabinet, now.
    500 mg. Vit. C at the ready. Will locate crappy sock for sacrifice tomorrow.
    Thanks a bunch,
    Condo Steve
    Condo Steve Guest
    The sock failed. What's option "B"?
    I rubbed that stain with a sock on the end of a pole for about five minutes. I couldn't see any difference.
    Thanks,
    Condo Steve
