If you turn the motor on and spin shaft manually and the motor spins up, the capacitor is bad. But fix the spring first and see if it starts on its own.
The spring may be from the centrifugal switch that sites on the end of the shaft. It holds the switch closed when the motor is off. You can see the spring in this photo:
