Results 1 to 8 of 8
Thread: Cloudy water??
    Default Re: Cloudy water??
    The CYA test, if you're using the disappearing black dot test, could be lower in clear water than in cloudy water, since the test relies on turbidity (cloudiness) of the water to obscure the dot.
    Check the manual for your SWCG--each unit specifies what the CYA levels should be. If you don't have the correct CYA levels, the unit has to work harder to maintain the chlorine in the pool, and that will cause your cell life to be shortened, so you'll have to replace it sooner. Also, it makes it very difficult for the unit to keep a consistent level of chlorine in the pool, leaving you more susceptible to algae outbreaks.
    Jun 2012
    Wisconsin
    the unit calls for 40-50 CYA level. So I should add conditioner until I get it up that high and don't read it when the water is cloudy?
    PS Thanks for your help. By the end of summer I will not be a newby and understand this water stuff better.
    I have a floating surface skimmer. Krystal Clear Model 637R filter pump. Krystal Clear Saltwater system Model CS8110
    15' round 3.3K gal AG vinyl pool; SWCG; Intex 637r cartridge filter; intex pump; 10hrs; HTH 6-way test Kit; utility water; summer: vinyl cover that came with pool; winter: Take down and store; ; PF:37
    Right--add conditioner until you get it up to the 40-50 ppm level. Remember that the conditioner is slow to dissolve, though--so once you've added it, either through your skimmer or in an old sock tied in front of a return, don't test for it or add more for at least 4-5 days to give it all time to dissolve and register in the water.
    Don't worry about being a newby--that's what we're here for!!
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 08:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
