Results 1 to 10 of 74
Thread: First Time using Taylor HELP!!!!!!!!!!!!!!
    BigDave's Avatar
    Default Re: First Time using Taylor HELP!!!!!!!!!!!!!!
    I'm a little concerned that you've reported FC of 0. You may be losing all your FC each day.
    Are you available to test / dose more often during the day? If you can, I'd recommend you dose 2oz to 3oz of dichlor at a time (a little overshoot won't hurt) and never let FC fall below the Best Guess minimum. If you can only test / dose once a day, I'd recommend you keep increasing the dose until you still have the minimum FC when you test again.
    Adding information from another post regarding this same situation to this thread in an effort to keep it all in one place. mroll, please continue this thread with your testing/chlorine issue so that you don't have responses to the same situation scattered out over the forum. I'll delete your other post.... thanks, Aylad
    __________________________________________________ _________________
    Using Taylor for 4 days now... I should mention first that the water is beautiful. HOWEVER, I cannot get Free Chlorine up. It went from .4 to 1.5 to zero!! Perhaps I test at the wrong time of the day. I test around 5 pm right before I add chemicals and run filter. Is this wrong?????
    PH is now normal..TA a little low at 70. (Just added baking soda) Two days ago CYA was non-existing too. Been putting in 1 ounce of dichlor a day but just now put in 1 1/2 ounces. Want to get these numbers in line so I can start using BBB. THANKS...
    So glad I joined. this forum is wonderful................
    As long as you don't have stabilizer in the water, the sun is going to deplete your chlorine. Try adding your dichlor tonight, then measure your chlorine after the sun is off the pool. In the morning, measure the chlorine before the sun hits the pool. This will tell us if there is something in the water eating the chlorine, or if the sun is consuming it during the day. If the loss is to the sun, then you simply need to add chlorine at some point during the day so that it never goes to zero. Once you have some stabilizer in the water, then you can dose the pool daily and should be able to maintain the levels you want. If the loss is overnight, then you have something in the pool that needs to be killed, and that's accomplished by shocking the pool.
    mroll is offline Subscriber Thread Analyst mroll 0
    Jun 2012
    Long Island, NY
    FC levels are about 2-2.5 in morning now. TA going up finally around 80-90. Tested CYA again yesterday. STILL
    No reading yet.. everything else is fine..Strange?
    15' round 5.7K gal AG vinyl pool; Bleach; Haywood DE filter; Haywood 1 1/4 pump; 4-12 hrs; Taylor K-2006 Tester; utility water; summer: solar; winter: Not bought yet; ; PF:21??
    BigDave's Avatar
    How much total dichlor have you added so far? You won't be able to get a reading until you work your way up to a total of about three pounds. Don't misunderstand, I'm not saying throw 3lbs in, remember what aylad said
    In 5700 gallons, each 2.5 ounces of dichor should add roughly 2 ppm of chlorine to your pool.
    Jun 2012
    Long Island, NY
    Well, only about 1 lb so far. At this rate ( 2 ounces per evening) will hit 3 lbs. when I'm on vacation. Should I have my son continue with the 2 ounces per night. Then when I get home it will have had bout 4 lbs of dichlor total put in. Will that make the CYA too high or normal range? Thanks so very much.
    BigDave's Avatar
    Do you have FC at the end of the day, before you add chlorine?
  1. Long Time Lurker, First Time Poster
    By MikeD in forum Dealing with Algae & Slime
    Last Post: 08-04-2012, 09:26 AM
  2. Long time reader, first time author
    By j_stewart89 in forum General Interest
    Last Post: 04-06-2012, 07:05 PM
  3. taylor- 2005 vs taylor-2006
    By axell in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 02-11-2012, 11:05 PM
  4. Just got my Taylor
    By Dooley11 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-04-2011, 12:03 AM
  5. taylor dpd #2
    By dhale63 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-11-2007, 01:44 PM
