Re: First Time using Taylor HELP!!!!!!!!!!!!!!
Adding information from another post regarding this same situation to this thread in an effort to keep it all in one place. mroll, please continue this thread with your testing/chlorine issue so that you don't have responses to the same situation scattered out over the forum. I'll delete your other post.... thanks, Aylad
__________________________________________________ _________________
Using Taylor for 4 days now... I should mention first that the water is beautiful. HOWEVER, I cannot get Free Chlorine up. It went from .4 to 1.5 to zero!! Perhaps I test at the wrong time of the day. I test around 5 pm right before I add chemicals and run filter. Is this wrong?????
PH is now normal..TA a little low at 70. (Just added baking soda) Two days ago CYA was non-existing too. Been putting in 1 ounce of dichlor a day but just now put in 1 1/2 ounces. Want to get these numbers in line so I can start using BBB. THANKS...
So glad I joined. this forum is wonderful................
