Results 1 to 10 of 74
Thread: First Time using Taylor HELP!!!!!!!!!!!!!!
    mroll is offline Subscriber Thread Analyst mroll 0
    Jun 2012
    Long Island, NY
    Default Re: First Time using Taylor HELP!!!!!!!!!!!!!!
    What were your FC, CC, and last night? What day are you leaving?
    Only did OTO test last night. (3+) Will do it all tonight around 5:30 -6 and post. Leaving Thursday. Thanks for getting back to me Dave.
    M
    15' round 5.7K gal AG vinyl pool; Bleach; Haywood DE filter; Haywood 1 1/4 pump; 4-12 hrs; Taylor K-2006 Tester; utility water; summer: solar; winter: Not bought yet; ; PF:21??
    BigDave's Avatar
    Please also do pH. 3+ OTO is what I'd like to see. We can run the recipie for your son for a couple days and see how it goes. Thanks.
    Jun 2012
    Long Island, NY
    OK Tested. FC 4, CC .5, PH 7.2 BUT when I look down into it, its more reddish. Anyway added 2 cups bleach and 2 cups borax. OH redid CYA and it read 30.. Dont know what happened the other day. 30 makes more sense at this time, right?
    (BTW how come on the OTO test they say 3 is too high and 1.5 2 is ideal???)
    BigDave's Avatar
    Sounds like you're in good shape. Follow the recipie for your son while you're home to prove to youself it'll work. Test chlorine and pH daily (FC and CC as long as you can). The bleach program should be pH neutral so get it near 7.5 before you leave and your son won't have to worry about it.
    Please dose 3 cups bleach not 2, I think 2 will let your FC get too low and you don't want trouble now.
    Keep us posted.
    Quote Originally Posted by mroll View Post
    These dosing recommendations are based on old beliefs that don't account for the presence and the effect of stabilizer (CYA) in pool water.
    Jun 2012
    Long Island, NY
    OK so you dont think I should add any more dichlor if CYA only 30???...so hard for me to read that..I see dot..I dont see dot..I see dot!! geez
    Also..there are some little pieces of black on bottom of pool..some about 1/4 inch,,some look like strips..not a lot but annoying since I see them again the day after I vacuum. I am going to try to remove it with hand skimmer today. Dirt? dead Algae?
    I dont know if its blowing in..very windy here ..The pool is used just by my husband and me..
    (should this be posted somewhere else??)
    Thanks..
    BigDave's Avatar
    I think for your goal of turning the pool over to your son with a simplified recipie for your vacation, you're fine. This is based on the fact that you can hold chlorine above minimum with daily dosing.
    We'll be glad to help you bring your CYA up a little more and figure out what the black stuff is after you return. The CYA test is the most difficult to read and subjective, I always have a hard time trying to figure out if I see the black dot or the shadow of my head.
    Will your son brush the pool for you as well or is that out of the question?
    I think for most sons, asking them to brush too is pushing it! I should know. I have 3 of them! If he'll just add some chlorine, I'd say you're doing well!
  1. Long Time Lurker, First Time Poster
    By MikeD in forum Dealing with Algae & Slime
    Last Post: 08-04-2012, 09:26 AM
  2. Long time reader, first time author
    By j_stewart89 in forum General Interest
    Last Post: 04-06-2012, 07:05 PM
  3. taylor- 2005 vs taylor-2006
    By axell in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 02-11-2012, 11:05 PM
  4. Just got my Taylor
    By Dooley11 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-04-2011, 12:03 AM
  5. taylor dpd #2
    By dhale63 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-11-2007, 01:44 PM
