Results 1 to 10 of 16
Thread: Confused
    Default Re: Confused
    If your FC is higher than the 5 ppm the kit will measure, here are the instructions to force it to read higher levels of chlorine...
    http://www.poolsolutions.com/gd/how-...d-testkit.html
    Lehigh Valley, PA
    Thanks for the reminder, Janet. I forgot the HTH kit limitations on chlorine testing. Now I understand the 'about'.
    May 2012
    Indiana
    I really just need to get the good test kit from Amazon. The FC color was at the top which is 6-10. What about the TA at about 30?
    In an vinyl pool, TA just functions as pH stabilizer -- and if you pH isn't bouncing all around, it's not something to worry about.
    Just to reiterate, to make sure you didn't miss it--with a CYA of 55, you need to keep a minimum of 5 ppm chlorine in your water at all times. Anna gave you some basic doseages and the results, so you need to test the water daily, and add whatever amount of bleach you need to get back up over 5 ppm. (I would dose it to about 8 ppm in the evening just to give you some wiggle room).
  1. confused on cya
    By johnlanciloti in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-30-2011, 08:47 PM
  2. I'm Confused
    By Lisa Tone in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-05-2011, 04:17 PM
  3. I'm confused
    By topless in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2007, 10:29 AM
  4. Confused about CYA
    By circlenranch in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-01-2006, 08:16 AM
  5. I'm a Little Confused ...
    By vinnygnj in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-28-2006, 09:28 PM
