We put up a 12' X 36" Intex type pool last week, filled with well water. We did nothing ( I know big mistake, we thought each other were going to take care of it...) but add a floater with HTH 1" chlorinating tabs (sanitizing ones), in 5 days it turned green overnight. We vaccummed and poured some shock in and it was still green today, so we are draining it now.
Do we use the guidelines for the kiddie pool maintenance or the ones for an Intex 12' or larger I found on a forum?
We are planning on scrubbing the pool out, turned our rust remover and water softner back on and then plan to fill it again. Should we do anything else? do we need to do the well water test if we have a rust remover and softner? we have aquacheck test strips right now. I know this will be easy, but seems so confusing right now. thanks
