Thread: Hayward HP21104T Heat Pump wiring
    May 2011
    Massachusetts
    Default Hayward HP21104T Heat Pump wiring
    hello all...
    I was looking into replacing my old heater with this heat pump but the local pool guys want big $$ for it. I was thinking of buying online and was wondering if the electric hookup was easy enough for my licensed electrician (replacing old Aquacomfort so subpanel is already by pool) or is there some knowledge of working around pools required?
    Thanks ~ Paul
    BigDave's Avatar
    Default Re: Hayward HP21104T Heat Pump wiring
    Ask you electrician about experience with pool work and comfort level doing it.
    You'll probably also need plumbing work.
  1. Hayward Titanium Pro Heat Pump 110k BTU ?
    By rcsup1 in forum Pool Equipment & Operations
    Last Post: 03-19-2012, 11:48 PM
  2. Hayward HP2100TCO replacement heat pump
    By dixie600mhz in forum Pool Equipment & Operations
    Last Post: 10-06-2011, 11:20 AM
  3. wiring for a heat pump(new IG pool)question
    By freddyttt in forum Pool Equipment & Operations
    Last Post: 09-08-2006, 01:01 PM
  4. Hayward Heat Pump - What type?
    By Calicat2u in forum Pool Equipment & Operations
    Last Post: 06-25-2006, 12:27 AM
