Re: Ozone or chlorine-above ground pool in FL
Chlorine!!!
Chlorine pools are not hard to keep, with a little basic knowledge and a good test kit. Ozone is not efficient for an outdoor pool, because the water is only sterilized while it's in the ozone unit itself--once it goes out into the pool, you still have to maintain chlorine in the pool to keep the water sanitary. And...if you're gonna have to keep chlorine in the pool anyway, why not save yourself the cost of the ozone unit??
Tell us a little more about what you have picked out--we may be able to either confirm that you've made good choices, or save you from making some mistakes before you get too far into it....
Welcome to the forum!!
