Thread: getting started with BBB
    Jun 2012
    North Carolina
    Default getting started with BBB
    Getting a late start. trying to open the pool and cannot get rid of green dark algae.
    Total hardness 250
    total chlorine 3ppm
    Free chlorine 3ppm
    PH 7.0 Raising a little at a time with borax
    Total alkalinity 20 ppm
    sanitizer 10ppm not wanting to add sanitizer having to backwash too often thought it would be a waste
    the pool is 22,000 gallon on ground pool with 8 foot deep end
    any suggestions would be greatly appreciated
    Thank,Tim
    Default Re: getting started with BBB
    Hi!
    Two questions--what do you mean by "sanitizer", since the sanitizer is the chlorine, and what is your CYA level? In order to kill off the algae, you must raise your chlorine to shock level, which is based on your CYA level, and hold it there until the green clears and you can go from sundown one night to sunup the next morning without losing more than 1 ppm of chlorine. This usually takes a few days, and you'll need to test/add more chlorine as many times a day as possible to maintain that shock chlorine level. Only then can you let the chlorine come back down, but what range you have to keep it in again will depend on your CYA level. Take a look at the best guess chlorine chart linked in my sig for a better explantion and the chart.
    Welcome to the forum!!
    Jun 2012
    North Carolina
    I meant stabilizer not sanitizer. The stabilizer was at 10 ppm I have raised the stabilizer 30 ppm
    If you'll fill out the pool chart form, we'll be able to answer better:
    Pool Chart Entry Form
    Pool Chart Results
    Meanwhile, a good start would be adding 7 gallons of PLAIN 6% household bleach to your pool each evening, until the water changes from green to gray or bluish (still cloudy). The first evening AFTER it changes color, add the bleach and then brush the pool completely.
    More . . . once you get your pool data posted. Say so, here, when you do so I'll be notified.
  1. just getting started
    By mike4017 in forum General Interest
    Last Post: 06-19-2013, 12:15 PM
  2. Just getting started...
    By willran in forum Above-Ground Pool Construction & Repair
    Last Post: 07-11-2012, 07:33 PM
  3. Just Getting Started here
    By les_garten in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-19-2011, 02:03 AM
