Thread: heat pump/cooler
    Jul 2012
    Default heat pump/cooler
    Any body out there using a heat pump/cooler,Water temps are heating up here in Az. We like the idea of having a heater and a cooler in one unit but havn't talked to any one who has one.
    Default Re: heat pump/cooler
    Hi, and welcome!! In Louisiana, we definitely don't need heaters, and the only cooling method I use is running the pump and night and running the slide while swimming. However, there are some folks on the forum that find that they can heat and cool with solar panels. I'm sure they will be chiming in shortly, but in the meantime you can use the google search link in my sig and search through the forum for other threads on the same topic. Until your registration is complete, though, you'll need to log out to read through the rest of the forum and the search threads.
    Welcome to the group!
    Sorry your post & membership got lost in the crush; not sure if you still need help, but your membership has been upgraded. -ben
  1. Opinion: Gas heater and a Chiller or Heat Pump w/cooler?
    By poolgal13 in forum Pool Equipment & Operations
    Last Post: 04-05-2013, 03:03 PM
  2. Cooler Pool
    By mikesthang in forum Pool Equipment & Operations
    Last Post: 08-13-2011, 10:41 PM
  3. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 08:37 PM
  4. A Cheap Pool Cooler
    By duraleigh in forum Pool Equipment & Operations
    Last Post: 08-19-2006, 10:41 AM
  5. Water heater/cooler
    By markeast in forum Pool Equipment & Operations
    Last Post: 04-19-2006, 09:26 AM
