Re: 7" Main Drain Cover replacement
Thanks for the info, unfortunatly it looks like GLI doesnt support anything other than pool covers and liners anymore. Looks like I will have to fabricate something...an adapter plate of some sort or something like that.
If I were to switch drain covers (the current covers were rated at 88ghp) will this affect the pump performance, or will I just have to adjustments to the drain flow paths?
