You probably don't need to do a 'conversion', after a single dose of Baquacil. Just chlorinate till it holds overnight, and you're good.
You may need to replace the cartridges, but you'd be better off with these anyhowUnicel C-4607 Replacement Filter Cartridge (Easy Set Size A or C) @ Amazon @ AmazonGet TWO -- these cartridges are MUCH higher quality than the OEM models. And CHECK first, to make sure you use the Intex "A", "B" or "C" cartridge.
Unicel C-5315 Replacement Filter Cartridge for 15 Square Foot Intex B Filter @ Amazon
Here's the recipe for Intex pool chemistry: http://www.poolforum.com/pf2/showthread.php?17055
Good luck!
