Thread: First test results with the PS234
    duraleigh Guest
    Default Re: First test results with the PS234
    Metal,
    You need bubbles. You seem to have a good grasp of the process. I would recommend you modify one or two of your returns (into the pool) and make a temporary fountain out of some 1/2 pvc and 45's or 90's. Your eyeballs on the return should screw right off and you can screw in a standard reducer and get your new "fountain" up and running in no time. Poor mans' "water feature" but it'll lower your alk and you can take it right back off if you are threatened by your significant other.
    The vac might work a little but I wouldn't want to listen to it for a couple of days.
    Thanks for the suggestion, off to the hardware store I go. One more question on
    the high Alk. I just started using the PS234 this year and have not measured my alk in the past. I was wondering what causes the high alk? I have an automatic cover that obviously was closed all winter and I was closing everynight last summer, could this be a reason fo the high alk or is there anything else that may
    have caused it?
    mbar's Avatar
    Ashland, PA
    Check your fill water, it may be high in alkalinity.
    Northeast PA
