First test results with the PS234
First time posting. Here are the results from the PS234 kit
FC:10.5
CC:0
TC:5 (was slightly darker than the highest reading of 5)
PH:7.4
TA:220
CA:260
CYA:38
Temp:68
I have a 20 x 40 vinyl 30,000 gal IG Pool with an automatic cover, a 1 HP
pump.
I did add some Bioguard Stingy Sticks about 3 weeks ago on the lowest setting ion my Pentair chlorinator but have not added any extra since. I have
been using 6% bleach from Walmart adding about 1 gallon every other day. Last night I added 3 ounces of polyquat algacide wich I have been adding every 6 days. The water is crystal clear but is the TA too high or should I
not worry about it?
