Re: Tough Algae even with high chlorine
I am ordering the k1515 kit meanwhile based on the guidelines on the test kit which says I need to add 5 gallons of 12% chlorine shock I added 5 gallons of Buckman's liquid shock which has 12.5% sodium hypochlorite at 6:00 PM. To be really safe I Dded another 3 gallons of the same T 9:00PM. Have bee brushing every 30 minutes Nd have the pump running from the main drain t the bottom.
I will post the results in the morning, but don't know how to test accurate TC with the kit i have which can only match color which is T the maximum of 5 (purple).
Thank you again for all the help.
24K gal vinyl IG pool, sand filter with 1 1/2 HP Hayward's pump
