Thread: Baquacil to Chlorine (generic chemicals)
    Jul 2012
    S Arkansas
    Unhappy Baquacil to Chlorine (generic chemicals)
    I read on your Baquacil to chlorine article:
    "step 3. Add four pounds of Pool Breeze(tm) Non-Chlorine Shock Treatment per 10,000 gallons of pool water to neutralize BAQUACIL.
    * Water may become a clear green."
    My question is do I have to use "Pool Breeze(tm) Non-Chlorine Shock Treatment"? I have some other brands for example, aquasilk chlorine free shock oxidizer and Baquacil chlorine free swimming pool oxidizer. Are these the same thing?
    If not, are there some household items I can use to accomplish this? I have spent $600 in <6weeks on Baquacil products...this is the first time I've ever used it...#pool chemicals broke me :-/
    Default Re: Baquacil to Chlorine (generic chemicals)
    I'll have Ben comment on this, but if you read through some of the threads in the Bacquacil conversion forum, almost all of them just used plain, generic, unscented ultra bleach. The pool is liable to turn all sorts of shades of weird colors, but you just have to keep putting the bleach to it until you're able to hold a chlorine level overnight in order to burn all the stuff off. Then a filter change, and you're ready to go--with MUCH less expense, time, and aggravation!!
    You DO need a good test kit to make this conversion the easiest--you need one that will measure high levels of chlorine, and will accurately measure combined chlorine. We highly recommend the K-2006 testkit linked in my sig, but at the very least you need the K-1515 that will perform the needed chlorine measurements for you.
    Welcome to the forum!!
    Sorry your post and membership got lost in the crush -- not sure if you still need help, but your membership has been upgraded. -ben
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. Baquacil to Chlorine help
    By billjan in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-25-2012, 11:16 PM
  3. Converting from Baquacil to Chlorine
    By Linda Fenn in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-18-2006, 06:07 PM
  4. Baquacil to Chlorine Conversion
    By godstreasures1 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 04-20-2006, 11:09 AM
