cloudy water
hi, my pool is not green anymore and I have the metal stain under control. See my post "green water"
but Now we have a cloudy deep end. You can see the drain but its not clear as a bell.Probably dead algae?
here are my numbers
FC 7.2
CC .4
Ph 7.7
Alk 70
cya 80
should I add bleach or use the calcium hypochlorite powder shock again? or something else?
16x32' rectangle 19K gal IG vinyl pool; bbb; jacuzzi sand filter; jacuzzi pump; 8hrs; Taylor 2000; utility water; summer: none; winter: vinyl / water bags; ; PF:6.3
