Thread: chlorine generator reading low salt
    Jul 2012
    ontario, canada
    Unhappy chlorine generator reading low salt
    I am a new pool owner.
    3 weeks ago I put in a 24' above ground pool with the goldline aqua trol. Its now reading low salt and won't generate choline. Its reading 2600 but I had the water tested and its at 3000. I took off the cell and its completely clean. Called the pool company and they told me to call hayward and I've been on hold for hours.
    I also tried the recalibration. Still reads low.
    Anyone have any clue?
    BigDave's Avatar
    Default Re: cholrine generator reading low salt
    Add salt. You need to satisfy the SWCG's sensor not some external test even if it is more accurate.
    Add bleach. If your SWCG is offline, it's not adding chlorine to your pool. No chlorine - swampy pool. How long has the SWCG been off? Do you know if you have any chlorine in the pool now? Let us know and how you know. If no or low, add bleach before you go get salt.
  1. Pump seals and salt based chlorine generator
    By BrianM in forum Pool Equipment & Operations
    Last Post: 06-05-2012, 03:55 PM
  2. Above ground salt chlorine generator
    By vinnybear in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-14-2011, 04:02 PM
  3. Salt water chlorine generator research
    By sevver in forum Pool Equipment & Operations
    Last Post: 07-23-2006, 08:05 PM
  4. Salt Chlorine Generator + 2 speed pump
    By jabre in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-16-2006, 02:39 PM
  5. Salt Water Chlorine Generator
    By blonde_b_tan in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 02:34 PM
