I have been reading this forum as much as I possibly can... The wealth of information is amazing.
I have the 16" intex sand filter with SWCG generator...
I have abandoned use of the SWCG until I can get all my levels in check and balanced.
My sole source of chlorine has been from bleach.
I was using the HTH 6 way until I received my Taylor K-2006 yesterday. Boy, the reagents in the HTH must have been old. Results are much different with the Taylor kit.
I ran the tests twice to confirm the results.
Here are my numbers:
FC - 0.8
CC - .2
PH - 7.2
TA - 60
CH - 80
CYA < 30 (I expected the CYA to be low, I drained 1/3 of the water to remove the small 1 1/4 intex connectors and replace with the 1 1/2)
I am looking for a recommended course of action. The water is crystal clear. I could "shock" by adding more bleach, but I believe the water is out of balance.
Ryan
