Results 1 to 10 of 13
Thread: Newbie with New 15'x48" Intex Pool
    Jul 2012
    Eastern Nebraska
    Default Re: Newbie with New 15'x48" Intex Pool
    thank you I'll get started tomorrow morning It's 95+ outside right now. I'll let you know how the culator works for me too.
    Leona
    If I'm not mistaken, the Culator takes a long time to work. Please, when you're finished using it, take some pictures of it from the outside, and cut open, so we can see what it's doing on the inside, too!
    Jul 2012
    Eastern Nebraska
    Smile Re: Newbie with New 15'x48" Intex Pool
    Will do, I understand that it will need to be replaced in about a month if/when it turns colors. When it does work I will buy more I just wanted to try it first.
    Leona
    Actually, I suspect it lasts indefinitely, as long as it's not gummed up with lotion and goop. The "every month" probably has more to do with CuLator's sales goals than anything else! Basically, in a pool contaminated with iron or copper, so long as the CuLator is not blue, orange or gummy with goo . . . it's probably still good.
    Quote Originally Posted by dandelion View Post
    Thanks. Remember it works over weeks, not days. Also you can SEE it's working:
    Also, note that discoloration of the BAG doesn't indicate it's working; it's discoloration of the beads, inside that is the indicator.
  1. CYA is 0 in Intex 10'x30" pool
    By wteal164 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-01-2013, 10:37 AM
  2. Intex pool "old" stock
    By SafetyBob in forum Intex-type Pool Setup & Operations
    Last Post: 02-22-2013, 11:20 AM
  3. New 15' x 48" Intex pool
    By AggiePool in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-28-2012, 01:58 PM
  4. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  5. Newbie with intex pool. Solar arc
    By Sunny4458 in forum Intex-type Pool Setup & Operations
    Last Post: 06-08-2012, 04:00 PM
