I readjusted my total alkalinity using Table K on page 63 in the Taylor booklet. I see that carbonate alkalinity is 109, not sure if that makes a difference.
I did some reading (okay, a lot of reading), and I see that adding liquid chlorine instead of using the bioguard tabs would be recommended.
As I understand it, I am to add liquid bleach every evening, after testing the FC level in the pool. I have a few questions:
1. What water chemistry tests do I need to check daily besides FC? All of them? I used up a full bottle of the CYA reagent already and I'm working on my 2nd :\
2. Should I remove the pucks from the chlorinator, or just keep them and let them dissolve?
3. Will my CYA level go down as I continue to use bleach?
4. Do you think the CYA levels have really risen that much since May?
5. Do you think that my water chemistry (that I listed above) is at all to blame for our green hair, or is it probably just the copper (as I suspected in the beginning).
I apologize for asking so many questions, and possibly being repetitive. Since I am new, my last post hasn't been approved and isn't visible yet. I also apologize for getting a bit off topic, but again, as I am new, I don't have privileges in all areas of the forum - thanks again!!
