The reason it will mess with your mind, is that running with CYA this high is contrary to guidelines EVERYWHERE, and I do mean EVERYWHERE, including here. I've been cautiously inching toward offering this as a possible solution, as I've been able to collect bits and pieces of data. In fact I'm currently operating a large public pool at around 120 ppm CYA.
But, I haven't re-written everything here and on PoolSolutions to reflect that, and the fact is I'm not 100% sure that some problem won't crop up, that ends up with the conclusion that maybe this wasn't such a good idea ofter all. But so far, everything I've found suggests that it IS a perfectly valid option. It's definitely working well at the public pool.
There are two problems that do exist.
First, in order to reach effective shock levels, you'll have to take your chlorine level above 100 ppm. That's can be an issue. It's hard to test, and can rapidly consume your testing reagents. Of course, you won't have to test often, since it won't come down very fast. And, that's another problem: at 100 ppm, you can forget about wearing fancy swimwear, and you may -- I'm not sure -- have some eye irritation. But, once you're there, you may only drop at the rate of 10 - 15 ppm per week, so it could take 3 -4 weeks to get back to non-shock levels!
Second, pH testing may be screwed up. Actually, we're being to think that that is NOT a problem, IF you take your pH reading quickly. But, we're not 100% sure, and if it DOES screw up pH testing, you'll either have to use an adapted test (with distilled water) OR you'll have to to get a pH meter (~$75, with buffers and such.)
Nevertheless, if I were you, I'd go ahead with the HiC2 (high chlorine + high CYA) approach. Here's what I'd recommend for you, based on your current situation, with some copper problems.
1. Use up any remaining tabs (they are hard to dispose of otherwise, and at this point, won't change the problem much.)
2. Add polyquat to improve filtration AND prevent algae, before we start taking your chlorine really high.
3. Add HEDP to keep the copper from staining AND to make it available to the CuLater units.
4. Add CuLator units to REMOVE the copper completely from your pool water.
5. Convert your pool to a borate protected pool to reduce algae problems (60 ppm borates, from 20 Mule Team borax + muriatic acid)
6. After all this is complete, and the CuLator units have been in place for 3 weeks, switch to high chlorine levels, and stop using polyquat & HEDP.
7. Purchase -- but do not use -- sufficient sodium bromide to allow you to deal with an algae outbreak WITHOUT extremely high chlorine levels. (Sodium bromide is converted to bromine by the chlorine, but bromine is NOT affected by stabilizer. We're going to try to avoid needed it, since it will create a much higher chlorine loss rate for a week or two after it's used. However, if you need it, you don't want to have to wait, so you need it on hand.)
8. Once you make the switch to high chlorine, you'll pretty much need to ignore advice from anyone but me, since most of the support team here is still pretty inexperienced with this. Janet (aylad) runs her home pool in the 80 - 100 ppm CYA range, so she's less so. But, you'll need to NOT panic if you post, and someone here is like, "OMG, you've got to drain right away!!"
The basic strategy is to
(a) use up your existing chlorine AND get rid of the copper.
(b) avoid algae problems during this period.
(c) add borates to reduce the chance of algae problems
(d) keep bromide on hand as 'bail-out' solution, that doesn't require 100 ppm levels of chlorine.
(e) switch to NORMAL chlorine levels that range from 20 - 35 ppm. You'll want to pick 1 day per week to raise levels BACK to 30 - 35 ppm, and then let if fall for a week.
I'd guess you'll spend $250 or so to add the borax, get the HEDP and CuLator units, and get the sodium bromide. The borax is a good idea in any case, and you need the HEDP & Culator for clean up, regardless. So, the only additional expenses are for the sodium bromide, which will be maybe $30.
You will need to decide how you will chlorinate. You have 3 options: a SWCG, bleach, or calcium hypochlorite. With a 30k gal pool, adding a weekly 10 - 15 ppm dose of chlorine with 6% household bleach will take 5 - 8 gallons of bleach each week. If you can get an 50# container of calcium hypochlorite, that will work for you, but again, you'll have to follow some very particular directions about how to use it, to avoid excessive calcium build up. Currently (and that may change), it's available at AmazonIn The Swim Cal-Chlor Pool Chlorine Granules 50 lbs.for about $145 delivered. You'd need about 3.5 - 5 lbs per week at ~$3/lb which would be cheaper than the bleach.
NOTE: your actual chlorine usage may be less than what I'm saying, but again, we just don't have the experience to be sure.
I'm going to go ahead and put all the links below, but if you get started, let me know, so we can tweak this.
Polyquat (3 quarts)
Using polyquat during metal clean up accomplishes two things: it helps kill or prevent algae, letting you run lower chlorine levels, and it is a very good clarifier, that helps you filter out any small metal particles that may form.(Probably available from pool stores, and possibly some big box stores -- but you MUST learn to ID it correctly. See the polyquat page for more info.)Kem-Tek 60% polyquat @ AmazonHEDP (1 quart 60% or 2 quarts 20%)
Nava 60% polyquat @ Amazon
HEDP is a liquid phosphonate that is pretty chlorine stable, and very good at keeping dissolved metals IN the water, instead of ON your pool surfaces. It can lift recent stains, OR it can be used along side of ascorbic acid, to keep the metals in the water, after the ascorbic acid is consumed by chlorine.Jacks Magic The Pink Stuff 1qt (60% HEDP) @ AmazonCulator + skimmer sock
20% KemTek HEDP @ Amazon
The CuLator product is a special patented plastic material, contained in a bag that goes into the skimmer, that can slowly take metals OUT of your pool water. We think it works, and have some evidence that it does, but not proof yet. (Not likely to be available locally.)1 ppm Culator @ AmazonBorax (29 boxes of 20 Mule team + 8 gallons of muriatic acid)
1.5 ppm Culator sold by Amazon, shipped from Periodic
4 ppm Culator sold by Amazon, shipped from Periodic
Poolmaster 16242 Poolmaster Skimmer Basket Liner @ Amazon (to protect CuLator from being damaged by scum)
Borax also can help control algae, but you have to add a LOT. It ends up costing around $50 per 10,000 gallons of pool water, for borax and muriatic acid, if you buy your borax at Walmart and your muriatic acid at Lowes. Soda ash is now frequently available at Walmart in the detergent section, at prices MUCH cheaper than the pool prices for the same chemical. If you ALSO need to raise your alkalinity, you can buy that instead. But if your alkalintiy is high enough, and you only need to raise your pH, it's better to use borax:20 Mule Team Borax @ Walmart
Muriatic acid @ Lowes (do not get the 'safer' muriatic acid; do read the "Using Muriatic Acid" sticky)
Bromide (4 lbs)
+ Be VERY careful about bromide, if you try to buy it elsewhere. There are multiple version of granular "yellow algae" treatments. Some contain sodium bromide; some contain ammonium chlorine, which is completely different and not desirable; some contain bromide PLUS phosphates.Nava Chemicals 652072097 Yellow Algae Remover, 2-Pound Bottle @ Amazon
Tropi Clear TC-4402-1 2-Pound Yellow Eliminator @ Amazon
Bleach or cal hypo
If you get ready to buy cal hypo, and the link I gave you is dead, let me find some more for you. Cal hypo, like all other chlorine products, is now being commonly blended with 'goop' and that's NOT what you want!
