Results 1 to 3 of 3
Thread: Pump Help
    Jul 2012
    Wellington
    Default Pump Help
    Looking for a little advice.
    I need to change out my pump; I have been looking at the Hayward EcoStar Variable Speed pump (SP3400VSP). I was told Hayward was the name to trust.
    After getting of the phone with a local Hayward dealer he is recommending a Pentair Intellifo VF.
    Anyone have any experience with either?
    Thanks.
    -KC
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pump Help
    You will probably get a lot of opinions either way but from what I can tell, Pentair has the better reputation of the two. Plus the Intelliflo has been in the field a lot longer than the EcoStar.
    However, if you already have a controller, I would go with the one that is compatible because that is a big plus and can reduce the total cost. If you don't have a controller, then I would recommend the Intelliflo 011018 as it has a built in controller and a great price point.
    Mark
    thread moved to correct location. sorry! -ben
