Re: Salt-only solutions? (not for chlorine generation)
I've heard that ocean salt water is around 30,000 ppm and most SWCGs require around 3000 ppm. The generator creates chlorine which is what sanitizes your pool. I don't know about ocean water, but I'm doubting it's possible to sanitize your pool using only salt (at any level).
Using a quality test kit and swcg, how is that not practically maintenance free? It's the lowest amount of maintenance possible.
