Re: Algae Problem with Cloudy Water
The brown stuff on the pool bottom is probably dead algae, which indicates that you're making progress. Keep your filter running but turn the SWCG off so you're not wearing it out. Use the bleach/liquid chlorine to keep your chlorine up, and follow Pooldoc's directions...
"You can test with an cheap OTO kit -- you can skip the evening dose, IF your OTO reading in the EVENING is DARK yellow with an orange tint. Otherwise, 8 gallons of 6% bleach EVERY evening till there's no trace of algae left. After the 2nd dose, BRUSH the pool carefully.".
That's a beautiful pool!
