Results 1 to 10 of 42
Thread: Algae Problem with Cloudy Water
    Jul 2012
    Oswego, NY
    Default Re: Algae Problem with Cloudy Water
    Just checked and we were at the top of the walmart kit for TC which was 5. So I just dumped in 8 gallons of bleach and ill let it run overnight and check it when I get up.
    Now the kit I have only shows TC up to 5 so in the morning am I looking for the DARK yellow with a little orange look? If it is low do I add more in the morning or another 8 tomorrow night? Do I leave the salt system off all day? Do I check the TC during the day or just again tomorrow night?
    You can force your OTO kit to read higher with a dilution method. You do lose accuracy with each dilution, but it is better than nothing until your K-2006 arrives.
    Testing Without a Good Kit
    If your CYA is around 50, you'll want to keep your chlorine level around 15ppm. Go ahead and test it again in the morning and add more bleach to bring it back up to 15. Each gallon will add approximately 2ppm. You can use that as a reference to help you figure out how much to add when you test. You can test as often as you have time for but at least twice per day and each time, take the chlorine back up to 15.
    Run your pump 24/7 while you are working to clear this up but leave your SWCG off.
    Hopefully, you'll see a big improvement in the morning.
    Jul 2012
    Oswego, NY
    Default
    Water looks a lot better this morning. Have some vacuuming to do of the dead algae. If this is alright to do? I do not have any distilled water to test with the kit I have to get a higher reading. I did the test the normal way and it was medium orange. So I'm not sure where this puts me on my way to 15. I did a test strip which has FC but doing 2 gave 2 different readings but both were under 10 (not very accurate). If I don't hear from someone soon I will dump 3 gallons in which should be close.
    I'm also confused on the FC and TC. My Walmart kit shows TC. Don't I want to know my FC, and how do I convert what the test is showing to FC?
    Interpreting colors of OTO testing: dark yellow (~10 ppm), orangey-yellow (~15) to orange (~30 ppm) to brown (> 60 ppm).
    OTO kits only show TC. Your Taylor K-2006 will let you show FC and CC. FC + CC = TC.
