Results 1 to 10 of 42
Thread: Algae Problem with Cloudy Water
    Default Re: Algae Problem with Cloudy Water
    Sounds like you are finally getting it under control. Great job!
    Mae West: Where've you been all my life, big boy?
    W.C. Fields: Oswego!
    Just remember, chlorine will KILL the algae, but it won't CLEAR the cloudiness from dead algae particles.
    What does your pool look like, at present?
    Jul 2012
    Oswego, NY
    It actually looks pretty good. A little better than yesterday. I could see the bottom of the deep end yesterday but its a little clearer today. I will jump in later today and look underwater with the goggles. Yesterday my visibility underwater wasn't very good but better than the day before by a little. I just vacuumed again this morning and did a brush. Less stuff to vacuum than yesterday.
    Jul 2012
    Oswego, NY
    Well I have been doing a lot of vacuuming and getting some settling in a lot of areas and I thought I was getting algae again. The water was not as clear as before. I tested last night and had FC 6.5 at 40 CYA and this morning I checked it was 6ppm. So I guess I don't have a algae problem. We have a new house going in next door and have several huge dirt piles next to house. I'm hoping this is only dirt settling in the pool and making it cloudy. I tried to swim down and investigate and it just disappears into the water when you brush it.
    Jul 2012
    Oswego, NY
    Well even though I only lost .5 overnight it is algae.
    My wife took a sample to school and looked at it under the microscope. Last week I did notice my FC was 2.5 so maybe it came back sometime then. I still have been adjusting the SWCG to get it where it was and must have had the purifier to low.
    So it looks like a shock is in my future in the next couple days, whenever I get a chance.
    Quote Originally Posted by bmlocal175 View Post
    Tonight would be a VERY good time to "get a chance". You can be sure that otherwise, the algae will be "taking their chance"! If it 'blooms' it will me much harder (by multiples, not %) to clean up.
    For a ~22,000 gallon pool, 6 gallons of PLAIN 6% bleach added in the evening would be a good dose . . .
    Jul 2012
    Oswego, NY
    I'm still seeing small amounts of algae or mustard algae on the bottom in some spots. I have kept the FC at or above 15 for 2 days and not losing more than .5 to 1 a night. How can I still see some algae? All other readings are normal and CYA around 40-50. pH is a little high, I'm assuming from the high FC. I've brushed and vacuumed almost everyday. Water looks good and is clear. Today I thought, that after I vacuum I pull the hose out and it sits there filled with water. Next day or two I vacuum with all the water still in the hose. Emptied it today after I vacuumed. Could this be the problem?
    22'x44' Mountain Lake 24K gal IG pool; SWCG; Ultimate Granular Filtration Millennium sand filter; Waterway 56-Frame Champion with Century Centurion 1.5hp motor pump; 12hrs; Just bought the 6-way from walmart and have the 2006c coming; utility water ; summer: ; winter: ; ; PF:5
    Jul 2012
    Oswego, NY
    Afternoon check.. Now its a very dark yellow. pH is 7.5-7.8ish. Haven't added anything today and cell is off.
    BigDave's Avatar
    Time for more bleach. When do you expect the k-2006?
    Jul 2012
    Oswego, NY
    Hasn't even shipped yet. I'll dump 3 gallons in now then 5 at dusk for the night.
  1. problem with green cloudy water..
    By phillies06 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-11-2012, 10:12 PM
  2. Problem with water being cloudy/murky.
    By TheGoose in forum Pool Equipment & Operations
    Last Post: 08-11-2011, 08:36 PM
  3. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  4. New Pool w cloudy water and algae problem
    By cokecraze in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-28-2006, 12:46 AM
  5. Another cloudy water problem
    By jwp0077 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-02-2006, 09:49 AM
