...if I'm doing it right.
Test results this AM with HTH 6-way:
Chlorine .75
pH 7.6
TA 260
TH 250
Notes: added 1/4c bleach after test.
Test results this evening:
Chlorine 3
pH 7.5
TA 240
TH 250
Notes: added 1/2c bleach 1 hour before testing, added CYA 1/4c at a time at 30 min intervals. Aerating water for 8 hours per day. Not going to test for CYA until I have infused at least 1/2 of the 4 lb container, as the kit only has enough material for 2 tests. If someone can point me to where I would be able to find just the reagent for the CYA test, it would make it a bit easier on this pool newbie.
I'm not sure I should add any muriatic to the pool while I'm trying to get the CYA in, since that will also lower the pH, albeit slowly.
I will be ordering the K-2006 in the next couple of weeks, so will have better info on what is going on in the water then.
I don't know what happened to my thread in the new guy section, as I can't access that any more. I'd really like to answer a couple of questions that others have asked in that thread.
