Results 1 to 10 of 71
Thread: Chem log, to see....
    Default Re: Chem log, to see....
    I'd call it 230 but a 10ppm difference on that test is insignificant, especially when it is that high.
    I'm not sure if anybody has talked to you about lowering your alk in a different thread. Please read the following:
    Lowering Alkalinity Step-by-Step
    Using Muriatic Acid Safely
    By the way, CYA doesn't really have much effect on pH.
    Jul 2012
    Mexico, Missouri
    Thanks, Watermom!
    I was unsure of the strength of the CYA on the acid scale, so I'll go ahead with the muriatic to lower the pH, and continue to aerate until the TA and TH come down.
    Charlie
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Jul 2012
    Mexico, Missouri
    Here are a couple of pics of what I was using to circulate/aerate the water, and what I'm using now:
    I don't know if copper would leach from the fittings or not, but from what I've read here, it may not be something I want in my pool.
    So, I made this with a replacement cap:
    Very clever! Thanks for sharing that pic! (And, you're right. You do NOT want copper in your pool.)
