Results 1 to 10 of 71
Thread: Chem log, to see....
    Jul 2012
    Mexico, Missouri
    Default Re: Chem log, to see....
    Question for the more knowledgeable folks here.
    I've put in about a gallon and a half of muriatic acid over the past several days, and can't seem to keep the pH down to 7.2 or below, yet the TA doesn't seem to be dropping that much yet. TA appears to want to hover for a while at the high levels, even with the spray rig I made. I realize the instructions said it will take a while, but shouldn't I have been seeing a more pronounced drop already? I'll test again tonight, and see where it is.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    BigDave's Avatar
    I looked over the thread and it seems that your TA has dropped from 250 to 210. That's almost 20%, sounds prettty good to me. The pH goes up because you are aerating (and have plenty of TA). The pH drops when you add acid (kinda the definition). TA also drops when you add acid. If you want to see it: aerate 'till your pH is about 8.0, measure TA, add acid to drop pH to about 7.0, let it mix for a couple hours, measure TA.
    Jul 2012
    Mexico, Missouri
    Thanks, BigDave.
    I guess I just got a little impatient this afternoon, after having added yet another 1/4c of acid. This evening's test of TA did actually show a drop to 180, but still in the error range from the last test. May be a "can't see the forest for the trees" type of blindness. Thanks for the reminder of where I had come from. Maybe I should have started a spreadsheet to record all my test results?
    Now if I could just figure out how to get the calcium down....Or am I OK with that at 250? Not sure what the saturation point would be where I would start to see scale on the ladder etc. I do note that there is some scale on the ladder legs at the waterline, from previous years use. I don't think it is from this fill.
    Charlie
    BigDave's Avatar
    Your pH rise will slow down as the TA gets lower and, I presume, you'll stop aerating when you get to your TA goal which will also slow pH rise (it's why your aerating). Remember, you're in the process of reducing TA - adding acid as often as you are is not a permanent state.
    Calcium Hardness at 250 shouldn't be a problem, just avoid chlorinating with cal-hypo.
    Jul 2012
    Mexico, Missouri
    Thanks for the info on the CH.
    Yes, I would quit aerating when I reach the goal of TA=100. However, my wife likes the sound of gentle splashing from return, so I'll probably need to keep an eye on this level, and adjust as needed with baking soda.
    Cal-hypo pucks available now, have a line in the ingredients "other chemicals, 4%" with no explanation as to what they are, so using them is a no-go for me. I want to know exactly what I'm putting in my pool!
    Jul 2012
    Mexico, Missouri
    Is there a Pool Owners Anonymous? I was told today that I'm obsessed with the pool, and Wife may be right. I can't get near that thing without picking up the leaf net and working out some of the tree leaves and other organics from the water. Is this normal behavior from new pool owners? or am I "a little touched in the head"?
    BigDave's Avatar
    Tetched? Whatever could you mean?
    Perfectly normal; you're learning something new that means something to you, you're invested. Don't let the haters bring you down. If you feel you're obsessed then backup but if you're just practicing your new hobby - Stand Proud.
  1. Does anyone buy chem from wholesalers?
    By pmeloy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 11-29-2011, 03:37 PM
  2. Calling All Chem Geeks (incl. THE Chem Geek) re: storing pool chems
    By elsie in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-10-2011, 11:20 PM
  3. Which chem to increase ph?
    By kelemvor in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-16-2011, 06:14 PM
  4. Trying to keep up w/ Chem Geek
    By ShelleyAnn in forum Pool Equipment & Operations
    Last Post: 04-23-2007, 04:30 PM
  5. Help with water chem., and SWG
    By guild1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-28-2006, 02:39 PM
