Results 1 to 10 of 21
Thread: Want to get the chemicals right ...
    Jul 2012
    Illinois
    Default Want to get the chemicals right ...
    I am sick to death of my pool right now, and would like some advice to help get the chemicals in balance. We've had the pool for 15 years, and have had a hard time with it for the last 5.
    This year, we lost it to green murk about two weeks ago, and went to the pool store to see what to do. When they told us it needed 95 bags of shock, we drained and refilled with our well water. We used a Metal Trap attachment on our hose to try to trap as much of the iron as possible, and used a separate 1.25 hp submersible pump to pump the water in the pool through a Culligan-type under-sink filter to trap even more of the iron. So here's where we stand today.
    We have not added any chemical, and took a sample to the pool store today. The measures the computer gave us:
    Water is basically clear, but not sparkly, and maybe a tiny bit green.
    pH: 8.2 (I know this needs to come down and just added a gallon of muriatic acid)
    TC: .5
    FC: 0
    CYA: 0
    TA: 288
    Hardness: 325
    Saturation index: 1.2
    Pool is 50,000 gallons, L-shaped, plaster bottom, fiberglass sides.
    Store wants us to add 15 lbs of stabilizer and 24 bags of Burnout 35, along with 10 pts of muriatic acid a day for 5 days and 5 qts of stain inhibitor..
    It's a BioGuard store, so we won't buy from them (too expensive), so any product recommendations, along with process recommendations will be greatly appreciated!!
    Default Re: Want to get the chemicals right ...
    It might help if you log out, go to the main forum page, and open the first set of threads in the second section, called chemistry for Intex pools. I realize your pool isn't an Intex, but the first sticky in that subforum, called " before you fill your...well water!" will apply to most any pool with metals in the water. Read through there, and if it doesn't answer your questions, ome back and post them, and we'll be glad to try to help.
    Jul 2012
    Illinois
    Thanks for answering me! I read the post you recommended, but still have questions ...
    The pool store analysis (test strip through a computer?!) said we have no metals. I guess it is possible that the metals are either sequestered or mostly out because we have been continuously filtering through our sand filter and the extra "culligan" filter.
    What I need to know is:
    1. What is the best way to get the chlorine up to maintenance levels.
    Super shock with about 10-12 lbs of dichlor (chlorine and stabilizer) shock. Or get it up slowly with separate CYA and liquid chlorine? I don't want to keep pouring chemicals and dollars in and having the chlorine disappear constantly.
    Can you help with that question? My husband is going to another pool store today to compare their advice with what the other store said and what I've read here.
    Thanks for
    In many parts of the country the cheapest chlorine you can get is the PoolBrand dichlor 50# bucket for about $105. I just got the last 3 buckets at my local store this AM, because we're draining a local country club's pool after a storm broke 3 glass tables in both their main pool and their kiddie pool.
    With a 50K gallon pool, 50lbs of dichlor is about 66 ppm of chlorine and 60 ppm of stabilizer. If your water is CLEAN and has no particular chlorine demand, that should last you about a month, and give you time to come up with something else. I'm not sure what part of Illinois you're in, or what your swim season is like.
    But, with a 50K gallon pool, your probably want to see if you can get a 100# container of cal hypo. If you were just now starting the season, you could probably do very well with a 50# of dichlor, a 100# of cal hypo, 4 - 8 gallons of muriatic acid, and possibly a few boxes of borax. Depending on what's in your well water, you might need additional chemicals to manage that.
    But, if you've been getting your advice from a pool store, it's no surprise you've had problems for the last 5 years. Pool chemical companies are desperate to keep up sales, in the face of losses to Asian chemicals, to SWCG's and to their on predatory treatment practices. As a result, their chemical recommendations have gotten 'goopier' and 'goopier' with more and more emphasis on high margin, low function, specialty chemicals.
    Jul 2012
    Illinois
    Sorry, I must not have been clear what I was asking ... I wanted to know if we should add chlorine slowly or full shock strength in one shot we went for the one shot and was probably not the right approach ...
    Values were:
    FC: 0 ppm
    TC: 1.1 ppm
    Ph 7.9
    TA: 309
    CYA: 5 ppm
    Hardness: 230ppm
    Metals: 0
    TDS: 500ppm
    We added 4 quarts GLB Algaemycin 2000, brought the ph down to 7.2, added 8 lbs of stabilizer through the skimmer then 3 hours later poured in 8 gallons of liquid chlorine. Next morning pool was clear but the color of tea (brown). Now, chlorine (free and total) is higher than my ability to quantify with my test strips. Ph is 7.0. Added 1 quart clarifier and 3 qts metal magnet. Now the pool is green, somewhat cloudy, holding chlorine, but making me want to throw in the towel. Anybody want to weigh in on what's next?
    Quote Originally Posted by Debits26 View Post
    Sounds like you may have iron, and that that's what your dealer considered as a possibility . . . but he loaded you up with algaecide too.
    If it was brown, but is now green and CLEAR, there's a fair chance you've got rust on the pool bottom. Color wise, blue water + orange rust creates an apparent green tint. So . . . vacuum the pool. If nothing changes, toss a couple of vitamin C tabs on the bottom, and see if it changes color -- if there are iron stains, the tabs will clear a small area.
    Meanwhile:
    + It's much easier to answer your questions, when we have the details about your pool in one place. We often 'waste' the first few posts back and forth collecting information. So, please complete our new Pool Chart form -- it takes about 30 seconds, but will save much more than that.
    Pool Chart Entry Form
    Pool Chart Results
    + Pool tests for metals aren't always reliable, for a variety of reasons. If there's a chance you may hve iron or other metals in the water you fill your pool with, using a bucket test can verify the problem: http://www.poolforum.com/pf2/showthread.php?16946
  1. Where to buy chemicals?
    By DanS in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-25-2007, 08:53 PM
  2. Need help with chemicals
    By Mariza in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-19-2007, 03:37 PM
  3. HOW MUCH Chemicals
    By chris cody in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-01-2006, 01:16 AM
  4. Where To Buy Chemicals
    By msb1766 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-19-2006, 01:24 PM
  5. Chemicals & #'s Have Me???????!!!!!!
    By MsSmiley in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-09-2006, 09:20 PM
