Re: Want to get the chemicals right ...
PoolDoc,
Thanks for all your help earlier this month! My pool has been looking good. I did the ascorbic acid treatment last weekend and most of the stains are gone. Thank you all for that great trick! My pool has really never looked better. The only problem is that while the acid was working, I had the filter on Recirculate, and lost about 5 inches of water depth. I had to add a lot of water the next day (adding some more metal into the mix).
Since then, I've been adding about 1 lb. of dichlor a day over the last week and now the water is white cloudy. We are unable to see the main drain through the water and I fear I'm on the verge of an algae bloom. After the acid treatment, I put 64 oz. sequestrant, and the filter has been running 24/7.
Here are my numbers today:
FC: 0
TC: .5
pH: 7.4
TA: 125
CH: 300
CYA: 35
Obviously, I need to get the chlorine levels up. I have added 5 bags of dichlor this week, and I added 85 oz. of polyquat. I'm planning to bring the chlorine up to shock level tonight (15ppm). If there's anything else I should do, or if any of this sounds off, please let me know.
Thanks again for all your help.
43K concrete L; 2.5HP Pentair; sand filter; PF:2.7; iron contaminated well water
Shallow: 20' + deep:20'xShallow:40' + deep:16' L' 50K gal IG pool; Trichlor feeder; Jacuzzi sand filter; Pentair whisper jet 2.5 hp pump; 24/7hrs; Aquachem strips; well; summer: ; winter: ; ; PF:2.4
