We typically recommend a CYA level of 40-50 for most pools. You can use the trichlor tabs for awhile as they will add CYA, but in the meantime until you get the CYA level up, you may find that you need to test and add bleach a couple of times per day. Another alternative is to just buy some CYA and add it separately. It will get the CYA in there faster for you. Your choice on that.
As far as pH levels, most people consider 7.4-7.6 ideal although anywhere between 7.2-7.8 is ok. Some pools have a particular pH that they like to be at. As long as it is somewhere within that range, don't fight it and just let it be. What pH reading do you typically get when you test?
Other tips to be successful? The best tip I can give you is to get a good testkit. The one we recommend is the Taylor K-2006 which you can get from the testkit page in my signature below.
Hope this helps and welcome to the Pool Forum! Come back if you have further questions we can help you with!
